mom net of inertia of beam with holes
this should be pretty basis but its been a while i wanted to check how do I account for the moment of inertia of a beam that has a slot in the center .
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: mom net of inertia of beam with holes
BA
reducedmoment of inertia reduction will be small. Subtrace w*d^3/12 from the original I of the beam, if hole is in middle... w-web thickness d-hole diameter.Dik
Mike McCann, PE, SE (WA)
Cheers
Greg Locock
Dik
