Concrete Crack
Concrete Crack
Does the crack in the attached picture pose a structural concern? I did a septic system design for a client and he has asked me about the crack but I don't have much experience with concrete cracks. Thanks for the advice.
RE: Concrete Crack
Give us a bit more info
RE: Concrete Crack
RE: Concrete Crack
RE: Concrete Crack
RE: Concrete Crack
RE: Concrete Crack
Crack can be repaired using epoxy injection of if it's just a matter of sealing the crack you can use polyurethane.
Dik
RE: Concrete Crack
Could be shrinkage, but the crack is wider at the top than the bottom implying rotational settlement to me.
Need a broader view (PICTURE) of the situation...
Otherwise patch and sack and monitor.
Mike McCann, PE, SE (WA)
