Composite Beam
Composite Beam
Is there someone who has experience with using composite beams in hi-rise structures. This is basically a U channel shaped steel filled with concrete, supporting composite decks. I would like to learn about the cost & schedule impact, serviceability and buildability of using such system as against using I beams.
Thank you!
Thank you!
