Test fixture and Motor
I have a hydraulic pump from a truck that powers 2 ram cylinders. I would like to build a test stand with an electric motor to power the small hydraulic pump to see if it works. How do I size and select the motor.
RE: Test fixture and Motor
-handleman, CSWP (The new, easy test)
