shaft sleeve with cartridge mechanical seal
I'm going through the guide specifications (reference specs not tied to a particular project) and finding some curious things. One is that we are requiring a shaft sleeve to be used on centrifugal pumps that also have cartridge mechanical seals.
My impression was that since a cartridge mechanical seal's only parts in relative motion and in contact (or close contact) are the seal faces, protection of the shaft with a sleeve should not be necessary.
What is the purpose, if any of using a shaft sleeve on an overhung centrifugal sewage pump where a cartridge seal is also used?
Thank you for any interest and responses.
RE: shaft sleeve with cartridge mechanical seal
