Multiple Selection but individual coloring
Hello everyone,
I am trying to apply a coloring scheme to a selection of elements but I'm having some trouble. Maybe someone can help?
Problem is as follows:
I want to select a whole bunch of thickness features all with different values, Then I want to assign a color to the thickness feature based on its thickness value. I plan to use an array to define the coloring scheme in RGB values, but I have not gotten that far yet.
Up to now I have used the selectelement3 tool to make a multiselection of the thickness features and just written a simple for loop to cyle through all the features. I though I would be able to apply the visproperties method to change the color of each thickness individually but I am getting an error message that the object does not support this property r method.
In the code below I made a simple rule for the coloring just to check whether anything changes. Please ignore the minimal error handling attempt...im still pretty new at this.
Can anyone help?
CODE --> VBSCRIPT
Language="VBSCRIPT"
Sub CATMain()
On Error Resume Next
' Initiate and selection
Set partDocument1 = CATIA.ActiveDocument
Set part1 = partDocument1.Part
If Err.Number > 0 Then
	MsgBox "Active Document is not a part document!"
Else
	On Error GOTO 0
	Set selection1 = partDocument1.Selection
	selection1.Clear
	' Select Features
	Dim strArray(0)
	strArray(0) = "Thickness" 'Selection Filter
	sStatus = selection1.SelectElement3(strArray, "Select Items", False, CATMultiSelTriggWhenUserValidatesSelection, False)
	' Define coloring scheme
'Create color scheme
	' Color the features
	For i = 1 To selection1.Count
		'Set length = selection1.Item(i).Value.Offset
		'strLength = length.Value * (-1)
		'Coloring formula
		R=10*i
		G=0
		B=10
		selection1.Item(i).Value.VisProperties.SetRealColor R, G, B, 1
	Next
	' Update the part
	part1.Update
End If
End Sub
RE: Multiple Selection but individual coloring
Hi, it is the entire selection that will change color, i.e
selection1.VisProperties.SetRealColor r, g, b, 1
NOT the individual elements... so you will have to alter your approach to only select one Thickness at a time...
regards,
LWolf
I guess the problem comes from
CODE -->
Visproperties is a Property of Selection.
so you have to pass your selection to something else, an array would do. then clear selection.
then loop the array and add to selection the single element and color it using selection.visproperties... then clear selection for the next element in array.
Eric N.
Thanks for the replies guys!
@itsmyjob. I actually just tried this and it worked pretty well except for two things:
1. Currently I loop through the array and then in order to select the individual feature I use the search method. This works pretty well but it is not very efficient. Any suggestions on how to improve this?
2. The features I am selecting sometimes have the same name, so when I search for a certain feature I sometimes select multiple features instead of just the specific one and (re)color them. I solved this now by assigning a temporary identification code to the name of all selected features (hat is all features are renamed with a 'unique' name, then I process them (apply correct color) and when that's done I name it back to the original name (which was stored in the array. This works fine, but again doesn't seem very efficient to me and leaves me wondering if there isn't a better way...Ideas?
thanks again!
-R
regarding your first question: why don't you use dictionary and store the entire selection1.item(i) in it?
later you can just select that particular dictionary entry...
regards,
LWolf
Hmmm... I'm not yet familiar with dictionaries so I don't know how they work, but I'll look into that. Thanks.
