journal move to layer
Ha All,
Does anybody have a journal which makes me select de object to move to layer 2 and then make layer 2 invisible?
I've made a journal for this only the selection of the I can't figure out?
Lars
Lars
Lars
NX11.0.1.11 native
Solid Edge
Inventor
RE: journal move to layer
Try this code:
CODE
Option Strict Off Imports System Imports NXOpen Imports NXOpen.UF Imports NXOpenUI Imports System.Collections Imports System.Collections.Generic Module layer_2 Dim theSession As Session = Session.GetSession() Dim sel As Selection = NXOpen.UI.GetUI.SelectionManager Dim workPart As Part = theSession.Parts.Work Dim dispPart As Part = theSession.Parts.Display Dim lw As ListingWindow = theSession.ListingWindow Dim newlayer as Integer = 2 Sub Main() Dim selectedObjectsArray() As NXObject Selectbody(selectedObjectsArray) lw.open Dim BodyArray(selectedObjectsArray.Length - 1) As DisplayableObject For i As Integer = 0 To selectedObjectsArray.Length - 1 BodyArray(i) = CType(selectedObjectsArray(i), DisplayableObject) Next If IsNothing(theSession.Parts.BaseWork) Then 'active part required Return End If Dim displayModification1 As DisplayModification displayModification1 = theSession.DisplayManager.NewDisplayModification() With displayModification1 .NewLayer = newlayer .Apply(bodyArray) .Dispose() End With Dim markId1 As Session.UndoMarkId markId1 = theSession.SetUndoMark(Session.MarkVisibility.Visible, "Start") theSession.SetUndoMarkName(markId1, "Layer Settings Dialog") Dim stateArray1(0) As Layer.StateInfo stateArray1(0) = New Layer.StateInfo(2, Layer.State.Hidden) workPart.Layers.ChangeStates(stateArray1, False) theSession.SetUndoMarkName(markId1, "Layer Settings") theSession.DeleteUndoMark(markId1, Nothing) End Sub Sub Selectbody(ByRef selectedObjects As NXObject()) Dim ui As UI = NXOpen.UI.GetUI Dim message As String = "Select body" Dim title As String = "Selection" Dim scope As Selection.SelectionScope = Selection.SelectionScope.AnyInAssembly Dim keepHighlighted As Boolean = False Dim includeFeatures As Boolean = False Dim response As Selection.Response Dim selectionAction As Selection.SelectionAction = Selection.SelectionAction.ClearAndEnableSpecific Dim selectionMask_array(1) As Selection.MaskTriple With selectionMask_array(0) .Type = UFConstants.UF_component_type .Subtype = UFConstants.UF_component_subtype .SolidBodySubtype = UFConstants.UF_UI_SEL_FEATURE_BODY .SolidBodySubtype = UFConstants.UF_UI_SEL_FEATURE_SOLID_BODY End With With selectionMask_array(1) .Type = UFConstants.UF_solid_type .Subtype = 0 .SolidBodySubtype = UFConstants.UF_UI_SEL_FEATURE_BODY .SolidBodySubtype = UFConstants.UF_UI_SEL_FEATURE_SOLID_BODY End with response = ui.SelectionManager.SelectObjects(message, title, scope, _ selectionAction, includeFeatures, _ keepHighlighted, selectionMask_array, _ selectedObjects) If response = Selection.Response.Cancel Or response = Selection.Response.Back Then Return else End If End Sub Public Function GetUnloadOption(ByVal dummy As String) As Integer GetUnloadOption = NXOpen.UF.UFConstants.UF_UNLOAD_IMMEDIATELY End Function End ModuleWith best regards
Michael
