part colors in draft
Hi All,
I've made a draft from an assembly (master model). In the context of the assembly i changed the colors of a few components.
Now when i make a second draft i've to change the colors again. Can I inherit the colors out of the first draft?
I don't want the change te colors of the parts.
Lars
Lars
NX11.0.1.11 native
Solid Edge
Inventor
RE: part colors in draft
Not to my knowledge.
If you would create the second drawing by save as the first, it would/ should keep the colors.
I assume that one could create a journal to record the colors of and apply the same in the next.
Tomas
Ok thnx
Lars
NX11.0.1.11 native
Solid Edge
Inventor
