Sewage sludge pipeline material
Good Evening from the UK,
For sewage sludge pipelines trasporting anything from 1% to 6% dry solids, what is the most popular material choice for the pipeline?
I more often than not specify cementlined ductile iron pipe whether below ground or above ground.
Interested to hear what others are specifying.
John
RE: Sewage sludge pipeline material
With the proposed concentration, you are not limited to ductile iron. PVC, stainless, or FRP may be used depending on the mechanical requirements.
