VB.NET To create part attributes
I need to create a lot of part attributes. I am trying to use 'setattribute' within a journal to create the variable and the value, but can't seem to set the category. Is it possible with 'setattribute' or should I use something else?
I would like to separate the attributes into logical groups 'Design, Manufacture, Inspection' ect
Thanks in advance,
NX Jockey
RE: VB.NET To create part attributes
I did what you are looking for with the “attributePropertiesBuilder” function. I am very new at programing, so there is probably a better way to do this. The sample code below takes the DB_Part_Name and brakes it down into separate attributes.
CODE --> vb.net
'Created By Jeremy Shooks
'Create attributes from DB_part_name
'6-23-2017
Option Strict Off
Imports System
Imports NXOpen
Imports System.Collections.Generic
Imports System.Windows.Forms
Imports NXOpenUI
Module NXJournal
Sub Main (ByVal args() As String)
Dim theSession As Session = Session.GetSession()
Dim workPart As Part = theSession.Parts.Work
Dim displayPart As Part = theSession.Parts.Display
'   Menu: Tools->Expressions...
theSession.Preferences.Modeling.UpdatePending = False
Dim markId1 As Session.UndoMarkId
markId1 = theSession.SetUndoMark(Session.MarkVisibility.Visible, "Expression")
Dim expressionDBPartName As Expression
expressionDBPartName = workPart.Expressions.CreateExpression("String", "TCeName=ug_askPartAttrValue(""DB_part_name"")")
Dim expressionTCeName As Expression
expressionTCeName = workPart.Expressions.CreateExpression("List", "TCeNameList=splitstring(TCeName, ""-"")")
Dim expressionLength As Expression
expressionLength = workPart.Expressions.CreateExpression("Integer", "TCeNameListLength=length(TCeNameList)")
Dim expressionMMProjectNumber As Expression
expressionMMProjectNumber = workPart.Expressions.CreateExpression("String", "MM_ProjectNumber=nth(1, TCeNameList)")
Dim expressionMMPartNumber As Expression
expressionMMPartNumber = workPart.Expressions.CreateExpression("String", "MM_partNumber=nth(2, TCeNameList)")
Dim expressionMMName As Expression
expressionMMName = workPart.Expressions.CreateExpression("String", "MM_NAME=nth(3, TCeNameList)")
Dim expressionMMHand As Expression
expressionMMHand = workPart.Expressions.CreateExpression("String", "MM_Hand=nth(4, TCeNameList)")
Dim expressionMMType As Expression
expressionMMType = workPart.Expressions.CreateExpression("String", "MM_Type =nth(5, TCeNameList)")
'   Expressions to attribute link
Dim objects1(0) As NXObject
objects1(0) = workPart
Dim attributePropertiesBuilder1 As AttributePropertiesBuilder
attributePropertiesBuilder1 = theSession.AttributeManager.CreateAttributePropertiesBuilder(workPart, objects1, AttributePropertiesBuilder.OperationType.None)
attributePropertiesBuilder1.DataType = AttributePropertiesBaseBuilder.DataTypeOptions.String
Dim objectsEXP(0) As NXObject
objectsEXP(0) = workPart
attributePropertiesBuilder1.SetAttributeObjects(objectsEXP)
Dim changed1 As Boolean
'------------MM_Hand-------
attributePropertiesBuilder1.Category = "MM"
attributePropertiesBuilder1.Title = "MM_Hand"
attributePropertiesBuilder1.StringValue = ""
attributePropertiesBuilder1.IsReferenceType = False
attributePropertiesBuilder1.Expression = expressionMMHand
changed1 = attributePropertiesBuilder1.CreateAttribute()
'------------MM_Type-------
attributePropertiesBuilder1.Title = "MM_Type"
attributePropertiesBuilder1.Expression = expressionMMType
'------------MM_Name-------
attributePropertiesBuilder1.Title = "MM_PART_DESCRIPTION"
attributePropertiesBuilder1.Expression = expressionMMName
'------------MM_PartNumber-------
attributePropertiesBuilder1.Title = "MM_Part_Number"
attributePropertiesBuilder1.Expression = expressionMMPartNumber
'------------MM_ProjectNumber------
attributePropertiesBuilder1.Title = "MM_Project_Number"
attributePropertiesBuilder1.Expression = expressionMMProjectNumber
End Sub
End Module
