Reorder Geometrical set based on given direction or spline?
Hello everyone,
In my short experience with CATIA V5 automation, there are two major factors that impact VBA automation:
1. Surface orientation (natural normal)
2. Geometry sorting
1. For surface orientation, i've been able to make a script that compares the natural normal vector of each surface, with a "master" direction vector.
Then, it's an easy step to decide which orientation I need.
2. As for geometry sorting, this is where i've hit a wall.
When you do a loop for example, of 1000 surfaces to be split to each other, you need to have the geometry properly sorted in your tree. See first picture.
Question: Is there a way to re-sort the geometry like this?
Maybe use a direction vector to sort it?
Or an intersecting spline or intersecting extrusion?
Any ideas?
