Subsea Plem
Subsea Plem
Subsea Plem
Can somebody advise me what the usual pIping specification is for the piping and valves within the limits of a subsea PLEM .I am used to using 31.3 but would like to know if there are alternatives used by others
Cheers
RE: Subsea Plem
Any of the pipeline codes you're using will cover PLEMs as well.
RE: Subsea Plem
Another alternative is to mix and match standards to achieve design/cost optimisation objectives. Naturally, that approach isn't generally applied for an 'off the shelf' strategy.
Steve Jones
Corrosion Management Consultant
http://www.linkedin.com/pub/8/83b/b04
All answers are personal opinions only and are in no way connected with any employer.
RE: Subsea Plem
The last Sub-Sea project I was involved with:
Manifolds - ASME B31.3
PLETs - ASME B31.8 / DNV-OS-F101
Hope that helps,
Cheers,
Shane
