use of temperature controller for non-temperature applications
Hello friends, I have a temperature controller left over from a previous project and I want to put it to good use. I would like to use it as a constant pressure controller (on a water distribution pump). This is a 4-20 mA input/output model, so the input can seemingly be arbitrary. I can set the the 4 and 20 mA mappings during setup. The pressure transmitter, on its part, outputs 4-20 mA too. I plan to use PID mode to drive 4-20 mA controller output (sent to VFD) and use one of the alarms as an 'on' switch for the pump.
So is the only drawback I will encounter is the units painted on the box being C/F instead of bar/psi or am I missing something deeper?
RE: use of temperature controller for non-temperature applications
Would seem to me that most VFDs can do all that by themselves. If you already have a sensor that puts out 4~20 then the VFD should be able to do everything. There's probably a parameter that can require the input to reach a certain level before the motor is commanded on.
Let us know how it works out!
Keith Cress
It was years ago, but a particular controller targeted for the plastics/packaging electric heat apps (a relatively slow response) and its proporational band setting maxed out 100 (gain = 1). It was installed in gas fired dryer with a massive burner, given the load size, with an incredibly fast response and its proportional band setting could not raised enough to slug down the response for stable control.
But I suspect that most modern controllers have very wide adjustment ranges and are not limited like that particular model was.
TTFN (ta ta for now)
xnuke
"Live and act within the limit of your knowledge and keep expanding it to the limit of your life." Ayn Rand, Atlas Shrugged.
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips.
The controller claims 150 ms/scan sampling rate for the 4-20 mA input, is that too slow?
