Stiffness matrix of simple shell element (Simple reasoning?)
Hi together,
I struggle a lot with the task to set-up a stiffness matrix for a simple shell element.
In Nastran, I have a 5x5mm flat shell with 1mm thickness (isotropic), represented by a CQUAD4 element.
Can somebody explain an easy way to setup the corresponding stiffness matrix? I already read that its a 24x24 matrix, 12x12 from bending and 8x8 from membrane stiffness, the rotational degrees of freedom are usually 0 but are given a small value to make the matrices invertible. Unfortunately, Ive not found an easy way to create these submatrices, thus the element matrix.
Any advice would be really appreciated
Cheers
Benny
Cheers
Benny
RE: Stiffness matrix of simple shell element (Simple reasoning?)
Derivation of stiffness matrices for shell elements is a pretty complex problem; its solution is usually a trade secret of software companies developing FEA codes. I would suggest you to have a look at the following webpage that provides reference to a book devoted to that subject (the book is supplied with a CD-ROM containing the source codes):
http://members.ozemail.com.au/~comecau/quad_shell....
Hopefully you will find that information helpful.
I guessed that,
but is it really so hard to set-up the stiffness matrix of a simple 5mm*5mm*1mm shell?
Maybe we do not understand what you really want to do !?!?!
If you are using an FE Program ( Like Nastran) why do you care about how to set up the stiffness Matrix ??
best regards
Klaus
I try to set-up the matrices to check a problem using a rather "analytical" or scientific approach.
I would require something that connects the young's modulus to the stiffness terms in the matrix. I want to show that varying the young's modulus by 1% is influencing the stiffness by 1%.
Is it possible to show that somehow?
Benny
E[k1, k2, ...]
Where factors k1 etc are independent of E, so the stiffness is proportional to E.
Doug Jenkins
Interactive Design Services
http://newtonexcelbach.wordpress.com/
thanks for your response.
for ANY type of element?
I found some literature which says that the material properties are included as a "Material property Matrix". (e.g. shell elements) Where also the Poisson's ratio etc are included. For this reason I was not competely sure, if the proportionality is the case for each application.
So, is the young's modulus direct proportional to each DOF of each element?
CODE --> element?
DOF ( degree of freedom) has absolutely nothing to do with young's modul
I think you are mixing things up without basic knowledge of FE method ...
best regards
Klaus
Thank you all for the effort.
My problem was that I had in mind, that the kind of element AND the kind of DOF(translational or rotational) play a role for the value of k11..k12..k22..etc.
My aim is still to gain some experience concerning how the stiffness matrix is set-up. To set up a global system stiffness matrix if only beam elements are used is quite easy to understand. The problem is that I wanted to doan analytical comparison or at least provide the theory behind it( concerning the relation between Young's modulus and the stiffness factors of a simple shell element (so K11..K12.. etc))
In my "understanding", if a simple beam element (from grid A to B) is put into focus, the rotational degree of freedom of B has another stiffness than the y-translational DOF of B for example. In the beam theory, the Young's modulus is included directly in the equations for bending etc. (E * I / l^3) etc.
For the shell theory, I just found some matrices that are looking like the equation including the young's modulus
: http://homepages.rpi.edu/~des/4NodeQuad.pdf (page 6, upper right matrix) The element stiffness matrix is therefore created using this "material matrix". But I would like to have some further information and understanding.For this reason, I would have liked to have a showcase for the role of the young's modulus in the CQUAD4 of Nastran (for example).
Thank you so far!:)
This has been done many times, isn't new, well written up.
As noted above, most (all?) elements in the stiffness matrix are proportional to E.
For a quad (having degrees of freedom that include in-plane & out of plane [i.e. flexural rigidity]) the answer to that is: yes. The stiffness is directly proportional to E. And that includes shear stiffness since G is a function of E & Poisson’s ratio.
The only thing I can't remember is the (in-plane) rotational (i.e. "drilling") shape functions.
as being not a "real" freedom ?
or because most element coding neglect it ?
(because it is essentially irrelevant to most solutions ?)
I think a lot of codes did/do. However, I've worked mainly with STAAD over the last 15 years and it has drilling degrees of freedom [dof] for both 4 node plate elements and 8 node solid/"brick" elements.
In the case of the solid elements, STAAD didn't use to have them. (In fact, IIRC, STAAD didn't have any rotational degrees of freedom at the nodes.) This use to make their solids prohibitively stiff (especially for dynamic analysis). Since they have introduced these dof, these elements have become much more flexible and acting closer to reality. (And ergo made their use feasible.)
Since the modifications I spoke of, the 8-node solid element [in STTAD] now is less stiff than the flexural stiffness of plates. (At least the last time I checked.)
It use to be, the solid elements in STAAD were ridiculously stiff.
No, I am talking the 8-node solid ["brick"] element. STAAD has never had anything but that for solid elements (that I am aware of).
@gravityandinertia :
Okay I think i used "analytical" in a wrong way.
To summarize it:
I have a structure (does not matter how it exactly looks).
I want to stiffen it by factorising the e-modul by 10%.
The other approach I want to compare to, is that I am not varying the young's modulus, but applying a factor to the stiffness matrix itself (so factorising each element of the matrix by 10%).
Now, I want to understand or to prove that both ways lead to the same result.
That's why I wanted to have a correlation between beam/QUAD stiffness matrix to the young's modulus.
According to my current understanding, there is a difference as the inplane rotational degree of freedom (r3) is not part of the element formulation ( in Nastran), and has to be therefore defined by the "K6ROT" parameter. This DOF stiffness is not influence by varying the young's modulus, but by varying the matrix itself.
Are my conclusion correct so far?
increase E by 10% should increase the model stiffness 10%.
no idea how to practically factor element stiffness 10%, unless you're doing this by hand. In which case you should clearly see the role of E, and so the self-fulfilling prophesy of what you're trying to do.
http://www.eng-tips.com/viewthread.cfm?qid=169523
Doug Jenkins
to sum up my latest information.
I analysed a simple CQUAD4 and I realized that varying Young's Modulus or Plate thickness IS influencing also the in-plane rotational DOF. So my previous statement that changing the young's modulus is not influencing these stiffness matrix entries but the direct matrix modification does, is wrong.
For the shell theory itself:
In the Nastran theoretical manual, there's a depiction of the material property matrix which is behind the "MAT1" card. In this case, the linear proportionality to the young's modulus is shown.
I found some information that a simple quadrilateral shell element can be superpositioned by membrane and plate-bending stiffness. The membrane stiffness is of shape 8x8 and the plate-bending is of shape 12x12. The K6Rot fills the last 4x4 to get the 24x24.
When I am focussing on Reissner-Mindlin plates ( =CQUAD4), I find some "different" matrices:
A 3x3 for the plate-bending and a 2x2 for shearing. For 4 grids, this would also result in a 20x20. But is this an identical approach to the previously mentioned one?
For this approach, the Bending stiffness (e*h^3)/(12*(1+v)) would lead to the the linear proportionality conclusion as well and the shear stiffness 5/6 * G * h as well (with G ~ E).
