Part Number Manipulation in BOM
I have used the forum in the past but this is the first time posting.
I am trying to find a way to manipulate my BOM table using NX8.5. I have legacy parts, that when the company migrated to a global teamcenter the parts had prefix added. For example PX-12345 has become PR_PX12345. Is there a way to get the number to show as PX-12345 in a BOM table without adding a parameter to the part itself. The parts are secured and can not be modified. I have been experimenting with replacestring() but I am not having any luck. Any help is greatly appreciated.
Scott
Scott
RE: Part Number Manipulation in BOM
That's all I've got if you can't modify the the part to add the attribute you need.
Dave
Automotive Tooling / Aircraft Tooling / Ground Support Structures
NX9, Win 7 Pro SP1
http://www.eng-tips.com/viewthread.cfm?qid=360636
Should be easy to extract the last part of the name with this.
Ronald van den Broek
Senior Application Engineer
Winterthur Gas & Diesel Ltd
NX9 / TC10.1.2
Building new PLM environment from Scratch using NX11 / TC11
