Stearm tracer for low pipeline temperature
I am working on a project on steam tracers design and I am facing a dificulties. I will state the process conditions:
-There is low pressure saturated steam available (~120-130°C)
-The process fluid flowing in the pipeline to be heated is Formaldehyde-52%
-The Formaldehyde temperature must be between 50-68°C
So I have worked with steam tracers before but the process fluid temperature was higher.
Now, it is only possible to heat through low pressure steam, but the steam temperature is too hot.
I do not consider other heating options other than steam tracing. Does any of you know how to precisely size the tracers line and its control system?
RE: Stearm tracer for low pipeline temperature
1. Why are you limited to "only" Steam and "only" Tracing?
2. Why not other fluids and other methods
3. What size product line do you have?
4. What size Tracer are you currently considering?
Sometimes its possible to do all the right things and still get bad results
It's the company's requirement. Their standards and they have steam available.
The company who designs this kind of plant uses steam tracers, so it is possible and currently the most cheap available.
The process tube is 2 1/2" 304 stainless steel std 40s
According to the Standard for steam tracer design I am folllowing I have to use 3/4"
With a heat exchanger, thermonic mixing valve and a small circulation pump you can deliver fluid that never exceeds 68C.
P.S. don't forget the pipe insulation.
Agree, electric heat tracing is much more reliable these days and more suited to heat sensitive materials, if you could use self regulating style electric heat tracing. You'll find this same recommendation in these pages in Perry.
I appreciate your tips.
I found something from TLV. It's a temperature control steam trap. I think it is an option to control the temperature.
