Steel column axial strength
I went to check a steel column in a parking garage that had some corrosion at the bottom. The column supports 6 stories above and is subject to only axial loads, no lateral braces and no moment connections. After cleaning the corrosion there was some loss in the sectional area. The column is corroded only at the bottom, from the top of the slab to the base, which is about 12". Now, How to assess whether the column needs to be reinforced or not? I am thinking of calculating the member axial strength and compare to the current sectional axial strength with the loss of area. if the sectional strength is equal or greater than the member strength then I won't reinforce. If not, then go through the calculations of loads on the column and see if the current section is acceptable.
Any input is appreciated.
RE: Steel column axial strength
Dik
