flow controllers/ regulators
I would like to be able to regulate the amount of free flowing air through some pipework. I am using a vacuum in order to draw the air in. Does anyone know of a company which sells a regulator which can work with ambient room pressures and regulate/control fairly small flows 5-30 Lpm cost effectively ? thanks
RE: flow controllers/ regulators
However, if you are needing better than 1% control then you have to go with a mass flow controller (they are not cheap).
