automatic update drawing views
Hi all,
I've set all drawing views to automatically update in the customer defaults and I've restarted.
Now when I open a draft the views don't automatically update. Can I change this behavior of is this a property of the already created draft?
Lars
Lars
NX11.0.1.11 native
Solid Edge
Inventor
RE: automatic update drawing views
Yes, it is a part setting that you will need to change: preferences -> drafting -> view -> common -> general -> workflow -> automatic update.
www.nxjournaling.com
i've to set this for all my drafts?
Lars
NX11.0.1.11 native
Solid Edge
Inventor
For all the Drawings you have created before you changed the setting in the Customer Defaults.
Be aware that that particular setting might already be stored in your Drawing Template. If that is the case then it should be removed from there. (if the rest of the users agree of course)
Ronald van den Broek
Senior Application Engineer
Winterthur Gas & Diesel Ltd
NX9 / TC10.1.2
Building new PLM environment from Scratch using NX11 / TC11
In other words, changing this setting in Customer Defaults has NO EFFECT on existing files, only newly created files that do NOT use a template or start part.
Tim Flater
NX Designer
NX 9.0.2.5 Win7 Enterprise x64 SP1
Intel Core i7 2.5GHz 16GB RAM
4GB NVIDIA Quadro K3100M
