Rain While Pouring Concrete Driveway/Wrong Concrete Delivered
We had a driveway and walkway poured recently and it started to pour rain. Puddles were forming on the half of the driveway that didn't have anything on it yet but they kept pouring and the concrete was looking quite sloppy. The rain got a bit lighter, but still kept falling on the concrete while they were trying to smooth it with the boards. We are concerned that the driveway is going to have problems because for several minutes during the pour, the rain got very heavy. I included a picture where you can see the drops. The walkway was being poured while there was a heavy downpour. How worried should I be with all the rain being mixed in with the concrete?
Not only that, but our order/contract specified that fiber mesh be mixed in with the concrete, but we found out the next day that they forgot to add it in! We did have wire mesh laid on the driveway...and it was also supposed to be on the walkway, but they forgot to put the wire mesh down there!
Any suggestions on whether we should pay this company? The sales guy is also the son of the owner and he was supposed to oversee the project but was out of town. He knew there was a good chance of isolated showers but ordered the guys to pour it. He didn't even realize the fiber mesh wasn't in the concrete until we examined it and texted him and he admitted it was not there.
When they pulled the boards off the walkway the following day, the edges were jagged and chipped and pieces broke off on the sides...which they just patched up.
Clean up was terrible with muddy cement from the run-off powerwashed down into the street in front of our driveway and also down the neighbors front curb and left there. And...muddy cement splattered from the powerwasher all over 2 of our newly leased vehicles in the street. The cement splatter was baked on by the sun all afternoon before we saw it so we now have to get it specially cleaned and detailed so we don't scratch the finish.
It has not been a very good experience.
Considering the driveway was poured when there was heavy rain, forgetting to have the fiber mesh included in the concrete and also forgetting to put the wire mesh in the walkway, completely splattering our vehicles with muddy cement (which baked on from the hot sun)....any suggestion on what would be a fair way to handle this?
We do not want them back at the house to do any more work because there is now a trust issue and we don't want any more bad experiences.
By the way...yes, I did research them and they have been in business for quite a while and this is also a company that has good reviews on Angies List and no complaints yet on BBB.
RE: Rain While Pouring Concrete Driveway/Wrong Concrete Delivered
Professional Engineer (ME, NH, MA) Structural Engineer (IL)
American Concrete Industries
https://www.facebook.com/AmericanConcrete/
What is your climate like? Do you use de-icing salts?
Dik
Saw cutting was done next morning. Are you saying soffcut is better than saw cut? We are in Michigan so nice summers, but snowy and ice in the winter. We have used de-icing but will try not to with the new concrete.
Sofcut is better than regular saw because the sawcutting is earlier. You want to cut the slab before shrinkage has 'taken over'; this happens early in the history of the slab. Sawcutting the next morning is likely a tad too late... maybe a midnight. The concrete should just be hard enough to prevent aggregate from 'ravelling' (kicking up) behind the sawblade.
You should also be looking at entrained air about 5% to 7%, and concrete strength should be 30 MPa, minimum. Slump should be 4" maximum. Proper curing of the concrete should happen.
Dik
Agree with Dik about WWF being of little value and rebar being best. To answer your question, to minimize rebar rusting the rebar needs to be 2" from the top (per Dik's comment). However, at the same time the rebar needs to be 3" above the bottom. The rebar, say #4, is 1/2" diameter and is installed in a mat (spaced bars running in two directions). Therefore the mat needs 1" of thickness. Total slab thickness, 3" + 1" + 2" = 6".
Many residential slabs are 4" thick.
A compromise suggestion:
1. Make the slab 6" thick (If nominal 6" lumber is used for forming the edges, 5 1/2" thick is ok).
2. Make sure the Contractor has compacted the soil under the slab before any concrete is placed.
3. Don't use WWF or rebar. Do use fiber mesh.
4. Put joints in both directions no more than 10' apart.
5. Don't use any kind of "cure and seal" compound. Do have the Contractor completely cover the slab with polyethylene sheets as soon as the concrete has cured enough to walk on without making any marks.
6. Tell the Contractor to go away and come back in one week.
7. Two or three times a day you place a garden hose under the polyethylene and keep all of the concrete as (continuously) wet as possible.
8. One week later the Contractor removes forms and the polyethylene then goes away for good.
www.SlideRuleEra.net
www.VacuumTubeEra.net
I thought I had posted this earlier, but, gremlins...
Dik
Dik - The OP wants fibers, I like them, but agree they are really optional.
Why do you like fibers? I assume you mean the plastic ones, which I consider to be useless.
In the mid-80's we were completing a new generating station. Our Consultants had been specifying WWF for the few unreinforced slabs used. Typically a limited number of small, 6" thick ones in "housekeeping" areas... say, just outside the doors of outlying pre-engineered building. I knew WWF has limited value; plastic fibers were being introduced as a replacement for WWF.
So, for a couple of our in-house projects at the plants used plastic fiber instead of WWF. Can't say that plastic fiber was better than WWF, but it was not any worse. Read the literature about plastic fiber possibly improving concrete toughness - that caught my eye. All our concrete has a "hard" life - impact from heavy items, large equipment bumping into it, etc. So, for the next plant we changed the "Criteria Document" that guides Consultants to our design preferences. Plastic fiber instead of WWF for minor 6" slabs.
Never tried steel fibers, with potential for corrosion from coal and process chemicals, didn't seem like a good idea.
But we digress. The OP's problem is a residential driveway. Where I am, most driveways are exposed aggregate or some type of stamped or applied finish. Very few plain concrete. If exposed aggregate, I think the fibres would create a fuzzy sppearance when the pressure washer does its job.
For reinforcement, we do tend to use heavier welded mesh reinforcement than I think you are referring to.
http://www.hanson.com.au/Portals/1/Documents/Produ...
I'm not a fan of welded wire fabric except in flat sheets (not the rolled stuff). For lightly loaded slabs on grade, I think any reinforcement causes more issues than it solves. There is no substitute for a proper mix design, properly placed, thickness controlled and proper/timely sawcutting.
As for fiber....I'm a fan of steel fiber for mix enhancement, not reinforcement. It significantly increases the toughness. I was on ACI Committee 544 on fiber for much of the 80's when there was great fighting and gnashing of teeth between the synthetic fiber producers and the steel fiber producers. A lot of testing was done and some good info came from that; however, the long running discussion between the importance of first crack mitigation and long term cracking (poly for first crack mitigation)will never be resolved and, in my (n)ever-so-humble opinion is a waste of time. Pick the fiber you want (or none), design the mix for it, place and finish it properly, then sawcut it as if there was no fiber in it.
Getting back to the OP.....that was miserable placement of the concrete. Have them remove it and have a competent crew prepare the substrate and place the new concrete properly as noted herein.
Agreed, an excellent reply, except I would still provide reinforcing even for lightly loaded slabs. Sawcutting is the real 'kicker'... has to be done and at the correct time (I cannot stress sawcutting at the correct time, enough).
Dik
