UG-29 - Stiffening ring - lateral buckling
In BPVC Section VIII, Div-1, Subsection UG 29 on stiffening ring, there is a paragraph that says "CAUTION: Stiffening rings may be subject to lateral buckling. This should be considered in addition to the requirements for Is and I's [see U-2(g)]". How is lateral buckling generally analyzed for stiffening ring or not analyzed based on certain engineering judgment?
Monk
Monk
RE: UG-29 - Stiffening ring - lateral buckling
r6155
Please, can you tell us the literature?
r6155
FYI, after some more digging, check out page 11 of this literature that I found online that provides a width to depth ratio of the ring section based on the Young's modulus and yield of material.
https://pveng.com/wp-content/uploads/2016/06/Exter...
The equation used in the above literature is based on theory of compact vs non compact sections. Here is a link for brief explanation: http://www.wikiengineer.com/Structural/SteelBeamCo...
ASME BPVC 2286 Figure 1.4.4. has the same information as guide for width to depth ratio. That case number has a lot of information and I am still slowly trying to digest everything.
Monk
1) PD 5500
2) AD 2000
3) BS EN 13445
r6155
