Cuni pipes repairing
Hello eng.,
Can anyone give me a reference, site, book, something about Cunifer pipes, the usual defects or common problems for this kind of pipes?
Thank you,
RE: Cuni pipes repairing
What service? What specific kind of copper-nickel alloy?
What physical characteristics? Dia, schedule, pressure, temperature, above-below ground, what length, what is the failure that needs to be fixed/repaired/repalced?
What is your schedule and budget limits?
What resources do you have available? Doesn't matter how good a repair could be, if you can't do that kind of repair?
What country? What are your liabilities if the repair fails? Are people or products or environment death/injuries/leaks possible if the repair fails?
What research have you done?
This is not a new material
Keep below the recommended velocity and ensure low quantities of particulates.
