How to calculate the saved Energy resulting from Cold water pipe isolation
Hi Professionals,
we have water cooling units ( 400KW/fixed rpm), there are about 400 m. / 5" pipes which are not isolated.
how can i calculate the amount of the saved energy if i isolate them.
r there tables/charts/software... ?
Best Regards
Paradiseinn
Best Regards
Paradiseinn
RE: How to calculate the saved Energy resulting from Cold water pipe isolation
Calculate the heat gain with insulation.
Subtract the second from the first.
TTFN (ta ta for now)
If the pipe is not used, it's good to isolate it for saving the costs of the energy and labor to maintain the pipe.
sorry it is insulation :)
The pipes are used, rest insulation work has not been done and postponed (can be) !!!!
i am an old engineer and have never worked with heat transfer and thermodynamic ( simply out of my work scope).
@IRstuff thank you for this tip but i need a formula / charts, .....
thank u all for replies
Paradisein
https://checalc.com/calc/inshoriz.html
http://www.engineersedge.com/heat_transfer/HeatCon...
thank you it helped a lot :)
Paradiseinn
