Submerged GRP tank - Backfill concrete surround
I have been asked to design a support for a buried WWTP GRP tank which is 11m long with a 3 m diameter.
The problem is that the tank is to be 0.8m deeper than the maximum burial depth as specified from the tank supplier.
The usual detail is a 300 mm thick backfill concrete surround.
I have designed a rc retaining wall/surround but this seems excessive? I would like to simply have a thicker backfill concrete surround but dont know how to design this. Is there any guidance on this?
RE: Submerged GRP tank - Backfill concrete surround
Dik
Sometimes if you agree to fill the tank with water to the top when backfilling / pouring concrete that is enough to stop the tank getting crushed.
