Pumps, pipes, measuring transmitters etc. for starch pipelines
Dear All,
I have quite a background (both theoretical and practical) on piping systems for water and/or water steam, but little background on piping systems for 20% (corn/potato/wheat) cooked starch - water solutions.
I was wondering if there is any literature with a practical approach to how are piping systems designed for distribution cooked starch (used as an adhesive for a production process)and how these systems differ from a newtonian-fluid piping system.
Additionally to above, I have some simple doubts like how should a pressure transmitter or temperature transmitter be installed in a cooked starch pipeline so as to avoid clogging in the path to the transmitter, etc.
Thanks for your very much appreciated help,
With best regards,
RSpain
With best regards,
RSpain
RE: Pumps, pipes, measuring transmitters etc. for starch pipelines
separating the transmitter and impulse line from the process fluid is quite common for corrosive or sticky substances.
Temp transmitter external strap on devices are also commonly used with insulation to gauge internal temperature without an insertion device.
As for design there are many alternatives. pumps are often PD ( gear type or diaphragm spring to mind).
Diaphragm seal + glycol/similar sounds certainly sensible, I will go further that path. Thanks.
As for piping, we do have some good evidence of appropriate pipe material, type of control valves, etc. We also have some good evidence (and access to) type of pumps.
My major doubts have to do with sizing process (diameter of pipe, flow pressure drops...)
I was wondering if there is any text book/study/etc to empirical macroscopic formulae that can be used for this sort of fluid (I really don't know how far away from a newtonian fluid is a 20%weight cooked starch aqueous solution is) where at least I can try to empirically fit my sensors lectures to have a model on which I can rely for estimating flow pressure drops
Thanks and best regards,
RSpain
