Simple gear pair: efficiency and output torque
Hi. I have a question about output torque and efficiency of a simple gear pair as shown on the picture. So, I have a pinion and a gear. I give an input torque Tp in the clockwise direction. Therefore, the pinion will rotate with ωp angular velocity in clockwise and the gear ωg in counter-clockwise. Then, I apply a load Tl in the opposite direction of the gear motion (clockwise direction). The gear is still rotating in the counter-clockwise. I neglect the friction between the gear mesh, but I consider the bearing friction both in pinion cp*ωp and gear cg*ωg. The moments of inertia of the pinion and the gear are Ip and Ig, respectively. My question is what the output torque To is because I want to find the efficiency of this gear pair. Thank you very much.
RE: Simple gear pair: efficiency and output torque
obviously.
However by ignoring the friction at the teeth you are ignoring the main source of inefficiency in a typical gear pair, so your calculation of efficiency is probably useless.
Cheers
Greg Locock
If To = Tl, I would not get a correct efficiency η.
η = Po/Pi = To ωg/(Tp ωp) = Tl ωg/(Tp ωp)
we know that rg ωg = rp ωp and ωg/ωp = rp/rg, so
η = Tl rp/(Tp rg)
In this equation, we can see that Tl/Tp has to be rg/rp in order to have η = 1. If I don't have Tl/Tp close to rg/rp, the efficiency could be much less than 1, for example 0.2, which doesn't make sense.
Cheers
Greg Locock
Incomprehensible.
Cheers
Greg Locock
Cheers
Greg Locock
It's weird to refer to it as efficiency because there is no loss of energy due to the mesh.
je suis charlie
The torque applied to the gear by the pinion is unaffected by load.
