molten sulphur filter
Hello everyone,
the molten sulphur filter started giving us at the output high ash rate, which reduces produtivity (will be used for production of phosphoric acid), it seems that the filtration panel connection with the collector is rather leaking sulphur without it passing through the panels, we are using o-ring type of gascket for sealing,
I wonder whether some one has faced this issue before, what kind of sealing should I be using to prevent leaking
Thank you
