Should a choke valve always be used in reinjection pipes (reinjection wells)?
RE: Should a choke valve always be used in reinjection pipes (reinjection wells)?
Please look at your entire post, from your handle (mechanical engineers work in hundreds of industries) to your one-sentence post and ask yourself "If I was sitting in (say) Russia would this convey enough information to allow someone to answer my question without a bunch of back and forth?"
You might want to address something like:
- What are you injecting (liquid or gas for starters)?
- What pressures/temperatures (is the fluid near a phase-transition temperature, chokes can be a huge problem near phase changes)?
- What magnitude of flow are you expecting?
- What is the goal of the injection (in Oil & Gas, it could be for secondary/tertiary recovery or simply for produced water disposal, other industries likely have other things they "reinject" for)?
- Are you experiencing a problem or is this a prospective design?
I've just spent 20 times as much effort on your post as you did. Could you give us a reason for caring enough to try to give you answers instead of questions?In my industry nearly nothing is "always", just like nearly nearly nothing is "never".
David Simpson, PE
MuleShoe Engineering
In questions of science, the authority of a thousand is not worth the humble reasoning of a single individual. Galileo Galilei, Italian Physicist
Long answer - see above.
Good luck,
Latexman
To a ChE, the glass is always full - 1/2 air and 1/2 water.
