Butterfly valve
Butterfly valve
Butterfly valve
Why butterfly valve named has BUTTERFLY..?
Can any u please replay
thanks in advance
RE: Butterfly valve
Because it looks like the wing of a butterfly?
RE: Butterfly valve
The disc of the valve is center-mounted on the shaft; as LI said, it looks (loosely) similar to the wings of a butterfly.
RE: Butterfly valve
Because if you don't torque the bolts to spec, it might fly away.
