.AddNewComponent - naming fail
I don't understand why I cannot add products and rename them using below code:
CODE -->
Sub CATMain()
	Dim TopNodeDoc As Document
	Set TopNodeDoc = CATIA.ActiveDocument
	Dim TopNode As Product
	Set TopNode = TopNodeDoc.Product
	Dim newNode As Product
	Set newNode = TopNode.Products.AddNewComponent("Product","")
	newNode.Name = "test1"
	newNode.PartNumber = "test2"
End Sub
It works once, I delete the new created product and after that it does not work anymore.
Using below code it works but it is not what I need.
CODE -->
Set newNode = TopNode.Products.AddNewProduct("Product")
I need this type of product:
instead of this one:
What am I doing wrong? :)
RE: .AddNewComponent - naming fail
Try this. This is working with me.
CODE -->
Sub CATMain()
CATIA.StartCommand ("Clear History")
Dim selection1
Set selection1 = CATIA.ActiveDocument.Selection
Dim product1 As Product
Dim products1 As Products
Dim Status As String
Dim Filter1(0)
        Filter1(0) = "Product"
        selection1.Clear
        Status = selection1.SelectElement2(Filter1, "Select a product to insert the new product", True)
        If selection1.Count = 0 Then
            Exit Sub
        End If
Set product1 = selection1.Item(1).Value
Set products1 = product1.Products
Dim PN As String
PN = InputBox("Insert the Part Number of product")
Dim product2 As Product
Set product2 = products1.AddNewComponent("Product", "")
product2.PartNumber = PN
product2.Name = PN
End Sub
Tiago Figueiredo
Tooling Engineer
Youtube channel:
https://www.youtube.com/channel/UC1qdlBeJJEgMgpPLV...
Thanks.
This solved the issue:
CODE -->
