Bysprint pro 3015 , 7,5' cutting head problem
Hello
We have an bystronic , bysprint pro 3015,by about 2 months,lately by about 1 week we started to have troubles cutting with the 7,5 cutting head and honestly don't get it why as we lack experience.
Everything is set ,we cut 4-5 sheets same thickness and then using the same parameters aa before on the same thickness sheet problems appear. Nozzle is centered correctly,lense is clean,nozzle is fine,same parameters it just doesn't work anymore. The cutting at one point seems like it has no gase ,instead of that orange colour while cutting is some blueish colour. We have all the gases nothing missing.
We tested two days in row and about after 4-5 sheets it just doesn't cut anymore. If anyone has any idea about what it could be I'd be really grateful :).
Could be the lense?it doesn't make sense cause it works 4-5 sheets perfectly.
What could it be?for me it seems like we don't get the cutting gase anymore.
RE: Bysprint pro 3015 , 7,5' cutting head problem
Chris Krug http://krugtech.com/
Maximum Up-time, Minimum BS
The O2 pressure is about 10 bars and I think we need at least 15 bars .. could that be?
Do you have any problems cutting any other materials/thicknesses? Have you tried a different lens?
