frecuency stability(PPM) in a PLL
Hello, my name is David.I`d like to know if the frecuency stability of the output signal in a PLL is the same as in the clock reference used in the loop.I mean, if the reference clock is 4 PPM, and the PLL has a multilplicative factor x15 to obtain a 300 MHZ output signal, has this output signal also a frecuency stablity of 4PPM?does the PLL only make the phase noise of the output signal get worse?
I`ll be deligthed to know any link to application notes or articles related with this toipic.
Tanks in advance
Tanks in advance
RE: frecuency stability(PPM) in a PLL
There is a lot of data articles, etc. search e.g.
<www.dogpile.com>
<nbucska@pcperipherals.com>
thanks again.
Search <www.dogpile.com> or <www.google.com> or
<www.yahoo.com> for PLL or phaselock.
or <www.ti.com> or <www.onsemi.com> or <www.fairchildsemi.com> appl.notes for PLL. Or
get from <www.amazon.com> Floyd Martin Gardner's
book about "Phaselock techniques"
===============OR===================
Do you have a specific problem?
I hope this could help you to better understand my problem.
Thanks for your former answer, by the moment I'll try with last links you told me.
AREVALO
AVERAGE of the phase error. Averaging == low pass filtering.
The frequency stability of the clock is a two edges sworld:
It may increase the max. frequency usable but generates more
noise.
