Paste Special with associativity of the copied body
Q: How do I copy a body and then paste with a link to that body I copied from.
How I would worked in Catia that had this function, I would start out with a simple body rep the stock.
As I progressed to op1 then op2 and so on I would do the copy>paste with link. That way If I needed to change something in op1 it would be seen in op2 on up. I need associativity when pasting.
Is this possible.
I am in 7.5 but will be moving to 10 soon.
Is this possible.
RE: Paste Special with associativity of the copied body
If they need to be in the same part then use Extracted Geometry.
Ronald van den Broek
Senior Application Engineer
Winterthur Gas & Diesel Ltd
NX9 / TC10.1.2
Building new PLM environment from Scratch using NX11 / TC11
extrated geometry is what you need.
