CATIA will not start
So I have a fresh install of CATIA. I did not change a thing and CATIA will not start..
When I launch from the icon. It shows up in processes that CNEXT and CATStart are running but CATIA never pops up.
Same with the license manager, Software Management.. I am stumped on this one.
Has anyone experienced this before?
RE: CATIA will not start
Hi Slaen,
Sounds like could be the environment file usually located in C:\ProgramData\DassaultSystemes\CATEnv by default. Perhaps its not referenced in the shortcut target or you have installed CATIA in a different directory?!
I did check that and everything checked out.. all the paths in the CATEnv point to the correct directories.
I did find the solution. It was an outdated Graphics Driver. After I updated it everything worked fine.
Thanks for your suggestion though. I appreciate it.
