Sizing an ion exchange pump
I have a small water treatment plant (15 m3/h) and part of the treatment process is softening (Ca/Mg removal by ion exchange). There is about 400L of resin in a 1000L tank. The water to the resin tank is supplied by a centrifugal pump (5-30 m3/h @ 2-5 bar total head). The resin tank is fitted with a Fleck 2850 control valve that can do service/backwash/regeneration/rinse functions. The pump is not fitted with any controls, only a throttling valve.
The problem is the following:
The flow requirements are dramatically different between operation and regeneration steps. As per resin specs, service flow is max 60 m3/h, so no problem there. But regeneration flow is 1-4 m3/h/m3, meaning that in my case it is 0.4-1.6 m3/h.
Can a centrifugal pump be operated so far off the low end of the pump curve?
Or maybe I am misreading the resin specs?
If not, what is the usual way of achieving this miserly flow rate?
Thank you all in advance!
RE: Sizing an ion exchange pump
Obviously the softener system manufacturer thinks it can, and whilst its not perfect it may be okay.
Ashtree
"Any water can be made potable if you filter it through enough money"
That's what I was afraid of. I've done my reading about ion exchange plant design, and while resin volume, service flow rate, rinse volume, etc, are discussed, I have yet to read anything about supplying the water to the system. Because the difference between service and regeneration flows is so dramatic I would expect this to be a common problem.
Would constant pressure control on the supply pump help solve this problem?
