Painting Quality Acceptance Standards?
We are having some items manufactured in Asia, and the paint quality of the final product has issues from application to shipping. We've sorted out the shipping and packaging issues, but a VP would like us to:
"add standard reference or class call-out for the paint quality such as Class I, II or III. I want to include a paint quality class so the requirement is clear and parts can be rejected for not meeting the cosmetic standard."
I've never experienced a "Class I, II, or III" paint quality call-out. Doing a search here on ET I found nothing pertaining to "Class I, II, or III" either. If such exists, please point me in the right direction. I have a suspicion that what needs to happen is that our company writes and defines our own acceptance criteria, publishes it as a specification, disseminates it to vendors, and then refer to it on our drawings. But, I could be (hopefully) wrong.
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read FAQ731-376: Eng-Tips.com Forum Policies: Eng-Tips.com Forum Policies to make the best use of these Forums?
RE: Painting Quality Acceptance Standards?
Dik
Are you using a primer on this ,or going with a one shot coat. I have not had good results with this , unless the electro galv is pre treated.
B.E.
You are judged not by what you know, but by what you can do.
Dik
In any case, http://quicksearch.dla.mil/ with a search for polyurethane pulls up a bunch of mil specs
TTFN (ta ta for now)
Dik
Polyurethane should have no problems coating zinc......alkyds will saponify.
ARCHITECTURALLY EXPOSED STRUCTURAL STEEL SHALL BE FABRICATED AND INSTALLED IN ACCORDANCE WITH AESS STIPULATED IN CISC CODE OF STANDARD PRACTICE
FINISH CATEGORY USED:
PROVIDE THE STIPULATED FINISH CATEGORY TO THE FOLLOWING ELEMENTS U/N:
ALL STRUCTURAL STEEL AND METAL FABRICATIONS: [AESS 1 | AESS 2]
AESS 2: FEATURE ELEMENTS VIEWED AT A DISTANCE > 6 M
SUITABLE FOR “FEATURE” ELEMENTS VIEWED AT A DISTANCE GREATER THAN SIX METRES. THE PROCESS INVOLVES BASICALLY GOOD FABRICATION PRACTICES WITH ENHANCED TREATMENT OF WELD, CONNECTION AND FABRICATION DETAIL, TOLERANCES FOR GAPS, AND COPES
AESS 3: FEATURE ELEMENTS VIEWED AT A DISTANCE <= 6 M
SUITABLE FOR “FEATURE” ELEMENTS, WHERE THE DESIGNER IS COMFORTABLE ALLOWING THE VIEWER TO SEE THE ART OF METALWORKING. WELDS ARE GENERALLY SMOOTH BUT VISIBLE; SOME GRIND MARKS ARE ACCEPTABLE. TOLERANCES ARE TIGHTER THAN NORMAL STANDARDS. THE STRUCTURE IS NORMALLY VIEWED CLOSER THAN SIX METRES AND IS FREQUENTLY SUBJECT TO TOUCHING BY THE PUBLIC
AESS 4: SHOWCASE ELEMENTS
SUITABLE FOR “SHOWCASE OR DOMINANT” ELEMENTS, WHERE THE DESIGNER INTENDS THE FORM TO BE THE ONLY FEATURE SHOWING IN AN ELEMENT. ALL WELDS ARE GROUND, AND FILLED EDGES ARE GROUND SQUARE AND TRUE. ALL SURFACES ARE SANDED/FILLED. TOLERANCES OF FABRICATED FORMS ARE MORE STRINGENT – GENERALLY ONE-HALF OF THE STANDARD TOLERANCE. ALL SURFACES ARE TO BE “GLOVE” SMOOTH
AESS C: CUSTOM ELEMENTS
SUITABLE FOR ELEMENTS WHICH REQUIRE A DIFFERENT SET OF CHARACTERISTICS THAN SPECIFIED IN CATEGORIES 1, 2, 3 OR 4
