How is this Assembled?
Hello Everyone!
I have been trying to develop a product which requires the assembly of a silicone slit valve in a plastic component.
I bought a product containing this assembly but I can't seem to figure out how it is done.
The picture below show what I am trying to achieve.
I am assuming that the same principal is applied to achieve the assembly in this picture:
Any advice would be helpful!
Abhinav
Abhinav
RE: How is this Assembled?
Another guess is a 2-part assembly with the silicone component over-molded/insert-molded into the full assembly, or assembled and heat-staked or ultrasonically welded to the transparent component.
TygerDawg
Blue Technik LLC
Virtuoso Robotics Engineering
www.bluetechnik.com
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read FAQ731-376: Eng-Tips.com Forum Policies: Eng-Tips.com Forum Policies to make the best use of these Forums?
