Misalignment Pipes Standards
I'm a very recent technician as a quality control in shipbuilding industry taking focus in pipe systems.
So in order to do a better examination and learn more, i've been trying to find some standards or guidelines that tell me wich tolerance a misalignment in pipes unions, coupling... might have.
In BV and DNV-GL standards i can't find nothing in concrete, so can you help me?
RE: Misalignment Pipes Standards
A.
You will get a lot of references from the net using combination search words : pipe alignment tolerances welding.
Use also the same for eng-tips internal search engine.
Best luck.
