Dual supply 110/230AC system
We have a system that uses 115 VAC for power, valves, etc. We want to allow it to run from 230V or 115V with the same model. What is the best way to do this?
RE: Dual supply 110/230AC system
TTFN (ta ta for now)
Better add frequency (60Hz vs 50Hz) to your list of things to consider. Solenoids designed for 120 VAC are often intended for 60Hz. If a transformer is used with 230VAC (and perhaps 50Hz) to provide the lower voltage, then solenoids might be unhappy with 50Hz (risk of overheating). Something to check, if you plans to use a transformer.
Can you use 24V or 110V DC as the valve control voltage and provide a universal power supply at the input (typical input range of 85V - 265V AC or thereabouts)
Just build this into your product and then you plaster a label across the power switch that the user reads before powering up the unit the first time. The label directs them to set the voltage in the little window to their local voltage.
You flip down the top little cover with the window in it which can only be done with the power cord removed (no shock possible) then you pop out the red fuse carrier and rotate it 180 degrees so the correct voltage will be seen thru the little window. reinsert the fuse carrier. Close the hatch. Plug the power cord back into the power entry. And, they're in business.
You do need to include the correct fuses for your product.
DKY Medical Filtering
DKY Commercial Filtering
Keith Cress
Maybe they are OK if used with only one fuse size, but if they are qualified on one fuse, but used in the other configuration I would check carefully and make a lifetime buy to avoid problems from the maker changing the design. I would also make the installation into a replaceable plate so that an alternate form factor could be used.
As it was there was quite a shock when the new, out of the box, fully tested, QC'd and QA'd, FDA approved design box failed to function because of the f'd up fuse holder that was badly designed.
(why does almost every electrical item seem like the mechanical design was handled by someone who took a drafting course but paid little attention?)
