Deform User Expression
Using NX 10.
I create a model with a User Defined Expression which is used by a three different sketches. It works pretty good. If I change the value of the Expression, the model updates.
Is there an option in Define Deformable Part, to made the User Defined Expressions Deformable? In the Define Deformable Part menu there is an Available Expressions area (see attached JPG) but nothing shows up in the area. Thanks.
RE: Deform User Expression
You first have to select the feature(s) you want to deform.
^The expressions assoiciated with those features will show in that Area. From there you select the expressions which you want to change.
Ronald van den Broek
Senior Application Engineer
Winterthur Gas & Diesel Ltd
NX9 / TC10.1.2
Building new PLM environment from Scratch using NX11 / TC11
