Export PDF - 3D Model with Pictures on Drawing
Hey guys,
I'd like to export a PDF file from my drawing. My drawing contains a 3d model with pictures on the drawing. the problem is when exporting as pdf the boundary of the assembly model is layering the pictures with its white background. So the pictures are behind the model frame.
Is it possible to change the layer position? I've tried to edit the boundary manually but it didn't worked out. It's taking the original boundary frame.
Thank you.
RE: Export PDF - 3D Model with Pictures on Drawing
Do you mean that you have placed a raster image on the model and the model lines are showing through the image? If so, I don't think there is a way around this. The model is always drawn on top. You can contact GTAC and open an enhancement request (ER).
If I've misunderstood, please post a screenshot to illustrate your issue.
www.nxjournaling.com
