VBA Macro to insert image in a userform (Calling the images from the worksheet itself)
I am trying to display an image on a userform depending on the choice of a combo box and the code below works fine:
picturename = "S:blablablabalabalab\blabla\" & name & ".jpg"
Userform.Image.Picture = LoadPicture(picturename)
However, I would like to avoid referring to the location S:blablablabalabalab\blabla\
Instead I would like to retrieve the image from an Excel worksheet itself (that I would hide afterwards).
In fact, the macro I am implementing will be used by several users on different computers, thus creating potential errors if they don't have access to that specific location (S:blablablabalabalab\blabla\)
Is there any way to that? call the images from the images from the worksheet itself?
Thanking you for your help in advance.
RE: VBA Macro to insert image in a userform (Calling the images from the worksheet itself)
@Fabien
this is not really a CATIA question, you should try https://stackoverflow.com/ for programming help
Eric N.
Thank you tesak for your quick response.
Indeed it is too complicated to use WIN API for my case.
As I had only 15 images to choose with the combobox, I decided to do differently:
I created 15 images control in the userform which are therefore overlapped and I copy/pasted ( picture property) my pictures in each one of them.
This method works fine and the images are saved in the Workbook itself.
