UT standard for monel shell plate
I have to make one shell for critical application.
plate to be used for shell is 13 mm. Material is SB 127 (MONEL).
I want to examine the plate by ultrasonic test. SB 127 does specify military standard for UT.
I WANT TO KNOW WHICH ASTM/ASME STANDARD TO BE USED FOR CARRYING OUT MOENL PLATE'S UT.
RE: UT standard for monel shell plate
I did not find any article/reference for standard for UT of Monel plate in Article 5.
