Flag Thickness
Flag Thickness
Hello All,
Can anyone let me know;
How to Calculate flag thickness in Pressure vessel and tank?
Thanks in advance
Thanks in advance
RE: Flag Thickness
RE: Flag Thickness
RE: Flag Thickness
RE: Flag Thickness
If so, these calculations are typically found in the original fabrication documentation calculations. The method for performing them depends on the original Code of Construction, including the allowable stress basis from the time of fabrication.
RE: Flag Thickness
"Flag thickness" may or may not be what you think " I think flag thickness mean... " and appears to be a phrase used by someone which ha no definition.
how you calculate anything is down to the inputs into the required calculations and checks as defined by the relevant design code for a pressure vessel ( Often ASME VIII) or a tank (say API 650).
This is an incredibly vague question with zero details so I'm going to stop now.
