Settings in nx
Settings in nx
Settings in nx
I have an issue if my drawing file is in DIN standard and i have to change to LATIN EXTENDED font can be possible?
Because every time i have to give new dimension by deleting old one which is DIN.
Note: all dimension are in DIN fonts need to change to LATIN EXTENDED.
Please help me out from this.
RE: Settings in nx
You can change this in the Drafting preferences. Section Dimension - Text - Dimension text.
For already placed Dimensions change it for one and apply. Then select all others and inherit the settings from selected object.
Ronald van den Broek
Senior Application Engineer
Winterthur Gas & Diesel Ltd
NX9 / TC10.1.2
Building new PLM environment from Scratch using NX11 / TC11
RE: Settings in nx
Ok thanks
Is there any macro?
RE: Settings in nx
You can make one pretty easy. Menu, tools, Macro and start record, preferences and set them what you want and then go back and stop the record. Then make a button for your ribbon tab and Hyper-link to the Macro.
