Flooded Bldg
Flooded Bldg
I been asked to help to resolve the bldg. was seeing 2" water on floor
Where shall I start?
What needs to be done?
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Flooded Bldg
RE: Flooded Bldg
Perhaps contact the dehumidifier people to dry the thing out. I think there are flood-salvage services that do that kind of thing.
RE: Flooded Bldg
One story metal building used as office, locker room, electric room in CT plant.
Floor is ceramic tile.
a swale goes by plant.
around the building was paved with concrete slab recently (4 yrs)
RE: Flooded Bldg
This is not sounding like a structural engineering topic yet!
RE: Flooded Bldg
If there is gypsum board on some of the walls, the bottom part which has been wet will require removal. If you don't do that, mould contamination will result.
RE: Flooded Bldg
RE: Flooded Bldg
RE: Flooded Bldg
I don't know where and how to find the source and where water coming from?
Anybody any ideas?
RE: Flooded Bldg
RE: Flooded Bldg
If you have a thermal camera, they can be a great help. If not then work your way through a list:
Is this potable water? Are there pipes nearby?
Is this rainwater from a roof leak.
What equipment is nearby that generates water (air conditioners etc.)
Are their fluid storage tanks nearby?
Are their drain lines in the the floor where water could be leaking from.
We might need to start a plumbing forum for this post?
RE: Flooded Bldg
RE: Flooded Bldg
Considering the fact that we know absolutely nothing about the building, I would suggest the chance of anyone being able to give specific help would be about 0.
Is there a water table problem?
is if partly underground?
Is it fully submerged?
Did someone leave a tap running?
If you get the water out, you might be able to see where it is coming from! Unfortunately, none of us are physcic, as far as I know, so I doubt that we can help.
RE: Flooded Bldg
You are not a newbee on these forums , you know better details give you better answers, so far you have not given enough information for anybody to give you a definitive answer , all you are getting is shots in the dark, you know better than that.
B.E.
You are judged not by what you know, but by what you can do.
