Responsibilities of a CVE and of a preparer of a stress report
Hi all,
I have a question that concern the legal aspect of our work.
I am an Aerospace Engineer with 3 years of experience in stress. I work for a consultancy company and at the moment I am preparing a very complicated stress report for a costumer company. Since there is a lot of work, it has been distributed in our office between some other engineers but I have no time to check their calculations also.
So, here comes the question: since I have to sign this document which is the part of my responsibility?
I has to be considered that this document will be also checked (signed) by an employee of the costumer company and from the CVE.
Thank you.
Thank you.
RE: Responsibilities of a CVE and of a preparer of a stress report
You could delineate who did which sections (traceability, but looks like a "piss-fight" to me).
You could do incremental releases (internally only), so that each author adds their piece, and eventually you get the complete doc
Yes you are right, it doesn´t matter to have multiple signs since the report is checked and approved.
It is a bit complicated because the data prepared by the other are not visible in the report, but I use them to make other calculation.
But here comes another question:
Which are the shares of the responsibilities of the Checker, of the CVE and of the Engineer that prepared the report?
Once the report is approved by someone else they have accepted the report and it's conclusions.
"CVE" is your airworthiness sign-off, "certification validation engineer" ?
Markeng512, in any case, it has become your responsibility to show that you have accepted the work, and the conclusions you make on its basis must be your own, too. Whether this is strictly fair, or if you have been given enough time to verify the work before you use it, is another matter, and one that we commonly face in engineering. Never enough time... Without turning this into the kind of fight that RB1957 warns about, make sure that you have expressed to the one who supplied the underlying analysis that you will rely upon them to make any corrections needed later, and to your superior (the one who assigned you this analysis) that they should make that person's time available to you, too.
When the document leaves your organization, it will usually be viewed as property of your organization, not to you personally, so corrections that come back will reflect on the company, not you personally.
STF
