Stainless Steel nameplate for subsea equipment
What is the best practice for attaching a stainless steel nameplate to a carbon steel structure that will be used sub-sea. The carbon frame utilises a sacrificial anode for corrosion protection. If the name plate is isolated it will corrode. Should the plate just be bolted or screwed to the frame?
RE: Stainless Steel nameplate for subsea equipment
http://www.fusionpoint.be
http://be.linkedin.com/in/fusionpoint
Dik
Cheers
Dik
The advantage of Cu alloys is that marine growth will be much less on them and you can actually find them later.
