Engine - Air filter design.
Hello Everyone,
Please help me with the calculation required to find out the area of air filter element/paper.(Gasoline engine - air filter.)
Any standard design document or guidelines for IC engine air filter design will be appreciated.
Thank you.
Vishal
Thank you.
Vishal
RE: Engine - Air filter design.
I would think that the suppliers of the filter media would have guidelines for the filtration velocity, which are likely dependent on all of the above. Have you contacted who you are proposing to buy the filter media from? That's the first phone call to make.
Fuel Injection - Diesel Engine 1.5 Liter.
Passenger Car with 10000 KM of service cycle.
I'm assuming that you're designing something and are not simply needing to replace an existing one. As the poster above implied, the auto parts store will happily look up the correct air filter for your vehicle for you to purchase.
I am designing air-intake system for a completely new vehicle.
I want some help on design calculation for number of pleats, area of filter element/paper, restriction etc.
Thank you for your replies.
More help on design calculation will be appreciated.
What do they recommend for the filtration velocity?
Altrnative ... Go to the auto parts store and buy an air filter for a vehicle with a similar engine, preferably from the same manufacturer so that they don't have to create a new part number. Use that.
SAE has a bunch papers that might be interesting.
Here is one -
http://papers.sae.org/2000-01-3317/
Here is another -
http://papers.sae.org/2012-01-1717/
