Canadian code for existing buildings
Is there something in the Canadian code comparable to 5% allowance/check in IEBC section 706 ?
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
Canadian code for existing buildingsCanadian code for existing buildings(OP)
Red Flag SubmittedThank you for helping keep Eng-Tips Forums free from inappropriate posts. Reply To This ThreadPosting in the Eng-Tips forums is a member-only feature.Click Here to join Eng-Tips and talk with other members! |
ResourcesThe world has changed considerably since the 1980s, when CAD first started displacing drafting tables. Download Now
Prototyping has always been a critical part of product development. Download Now
As the cloud is increasingly adopted for product development, questions remain as to just how cloud software tools compare to on-premise solutions. Download Now
Engineering-centric businesses face a number of challenges today, but unmanageable design and change processes don’t need to be counted among them. Download Now
RE: Canadian code for existing buildings
Dik
OHJAHJ, whereas, Ontario the application of Part 11 is a much better approach. Not looking for a fight, the OMB in Ontario is quite friendly to the application of Part 11 in the event anOHJAHJ objects... but, time consuming.Dik
One issue I have been having with Part 11 of the Ontario Building Code is this:
- Remedial action is needed if the Performance Level (PL)of an existing building is reduced due to construction work.
- PL is reduced, per the code, if the Major Occupancy is changed, Live Load is increase, or the occupancy load is increased by 15% or more. What happens if a shear wall is removed, for example? It is clear that the PL is increase in this case but the code doesn't mention anything about lateral loads, unless part 11 is considering wind and seismic loads Live Loads, which is inconsistent with other parts of the code.
Dik
